Source for gasket for fixed portlights?
I need to replace the gasket which holds the glass within the frame of the four trapezoidal fixed portlights. Where can I source the right type?
SpudE36RH
Watching, i broke one port glass trying to get frame off. When I check with Holland Marine in Port Credit Ontario I Can let you know.Might be similar to Catalina.
Try this Blog entry from Goldenstate, with good links within:
Especially:
We also have a Master Thread on Fixed Window Replacement.
Stuart 28-2
I used this kit from Catalina Direct on my E27.
I bought the same kit to use for my 1988 E28-2. Now that it has arrived I can see the gasket is not the same dimensional cross section as my original seals. Did you have a similar difference? Did it still work?
See photo.
Parrothead
CR Laurence glazing vinyl comes in a wide variety of sizes. It's available from DK Hardware but expect a 100 ft. minimum order quantity.
I think the GS111C extrusion might match the one in my image at the top of this thread. While 100 ft is about 4 times what I need, $61 to get the fixed port lights in order is not a bad price.
