There is another thread explaining how I installed the new traveler. Yes, it was absolutely worth it because with the earlier Schaefer model I had to climb around the dodger to muscle the traveler car along the track. Now I can do everything from inside the dodger. My boat came with the longer track so I just replaced what was there. That too is definitely a plus because with mid-boom sheeting and a longer track I almost never have to use a vang (which I cannot keep in place because it interferes with the forward opening main salon hatch). If you do not have the long curved track, it would be much easier to install straight track with risers from Harken ($$$) or Garhauer as a replacement. However, while the straight track is better because moving the car does not change the tension on the main, I think the curved track looks better.
The coach roof should be able to support the load on the main, but make sure you have backing plates under the risers. I calculated that the load on the mainsheet could go as high as 2500 lbs on the 32-3 using the formula from the Harken website. (I made it into an Excel spreadsheet, which it attached as a zipped file, so you can see for yourself if you have nothing better to do.)
