Marine surveyors and insurance companies require two hose clamps on all fittings below the waterline, and most such fittings will accommodate two. Makes sense, because the attachment of the hose to an open seacock is part of the integrity of the hull.
Hoses to worry about are old, brittle bilge hoses, typically the big-diameter one for the Whale pump. Or any drain or bilge hose that looks suspicious, although since they're not under pressure visual inspection is usually good enough to let you sleep at night.
The engine hoses are more critical, since they get hot, can burst in event of some other engine disaster, and are susceptible to failing inside. In general they should be hard to the touch, not squeezable like Charmin, not bulging, not ragged, not split at the end because the former installer bought the wrong (expensive) hose, and well clamped. Some engine hoses have dates on them. Replace at 10-20 years? Anyway, have a close look at them, leaks or weakness are unacceptable.
