Hi all,
I have a 1971 E29 with tiller and have done some coastal sailing with 6-8 hours on the tiller, wanting to do longer multi day voyages and now realizing a tiller pilot is in order.
Has anyone installed a Raymarine ST1000+ or ST2000+ on an E29 and if so do you have any mounting recommendations?
Also generally would like to know if anyone has notes on experiences using these tiller pilots without any connection to wind, speed, or nav devices, since I’m planning to use this to set a heading manually based on my handheld gps. Does the internal compass on these really keep the heading?
Finally, my tiller has always felt a little loose on the rudder, where there is a 1” back and forth on the tip of the tiller where it doesn’t feel like the rudder is tracking… there is some vertical play on the tiller lower bracket by the mount and when pulled up and out away from the hull about 1cm, the play in the tiller goes away. I’ve tried installing rubber gaskets to keep the bracket higher and it makes everything solid, but they keep wearing out and falling off. At first I thought this was a loose rudder but I’ve inspected it and seems firm, plus I’ve sailed it for 3 years in strong winds and nothing has broken yet. All in all, I mention this because I’m wondering if a tiller pilot is going to be putting more force on the tiller and if this is going to potentially cause problems with a tiller that has some play in it, or potentially wear out and break faster.
Any and all insights would be much appreciated!
- Rob
- Rob
