jgarmin098
My Hurth transmission on a 1988 E-32-3 with Universal 25XP is acting strangely when shifting into forward. After the engine and transmission are warm, when I shift into forward the transmission will seem to jump into and out of gear repeatedly. The frequency is on the order of once or twice per second. Of course, the problem is intermittent. If I advance the throttle above idle while it acting up, the transmission stays in gear and operates normally.
The shift cable is a bit sticky going into forward and the transmission seems to come out of forward when pull the shift level back only part of the way to neutral.
Any Ideas?
Any Ideas?
