Universal 5432
Rocinante33
Gary,
I have no experience with that, but ouch, that could be co$t prohibitive unless you find someone parting out an old engine. Or maybe a good welder could do some magic.
You say erosion, do you mean corrosion? If so, how so? It is freshwater (coolant) cooled and isn't the boat in the freshwater lake?
Gary Peterson
Marine Guy
I have not experienced any issues to date. I just wonder if any owners have. Changing anti-freeze every few years is a good idea so one doesn't let their cooling system Ph get out of balance.
Rocinante33
If you do that it should be pretty immune to erosion. :egrin:
It will probably last beyond the life of the engine.
The raw water pump and the heat exchange, because the are in contact with raw water, are a lot more prone to corrosion
