Rick R.
Hello Fellow Vikings,
While replacing the impeller today I noticed it is time to replace the Sherwood Raw Water Pump. I have searched online and discover that the Sherwood part# 302648 is no longer made and is now Werherbeke part 42175 and is a whopping $534!
I have searched here and found where some have replaced with an Oberdorfer 202M-15 which is a lot less expensive but it sounds like it requires some machining or modification.
Questions:
1) Does anyone have a source for the Sherwood at a good price?
2) Can someone share exactly what modifications need made to make the Oberdorfer fit instead?
Many thanks
RicK
Questions:
Many thanks
RicK
