Wood, Interior "Unscrew-ums" They really work!
Includes wood work and finishes including all interior, cabin sole and others (excludes exterior brightwork).
I picked up one of these, several years ago, after having to replace several broken screws in our cabin sole pieces. I decided to be ready for a someday 'next time'. Those sole pieces are screwed down thru an FRP flange. After many years I removed all the sole pieces for refinishing, and ended up enlarging the hole around the broken screw, filling it in with epoxy, and then re-drilling.
Worked fine, but something more efficient really was needed for the "next time." And, here we are in 2025.
So yesterday I was inserting some #6 bronze screws, thru a teak trim batten, and into some solid glass. In a moment of overlooking the ramifications..... I had put in some thickened epoxy to back fill around a 1/4" hole I had to create because the thin surface panel (honeycomb) does not 'hold' screw threads very well going straight into it.
I was tightening the little bronze screws, about ten of 'em and belatedly realized that several had started turning way too easily when almost in. My error was drilling a straight hole like I would in thin surface or in soft material. The hard epoxy can allow threads to cut, but cannot... expand to allow the tapered screw to have room.
So, here I was, contemplating my stupidity, and gazing at little shiny round screw ends, buried in the hard epoxy!
Well, Ratz, as we salty mariners sometimes exclaim. :(
Tried the little tubular "Unscrew-um"device, with its 'teeth' on one end. Slowly turning, in reverse, as the tube cut its way inward, and embraced the broken screw end. Way Cool! ----Just like in their video!
Next I properly re-drilled each hole with a "countersink drill" ( i have a small set sourced from the Woodsmith Store) with its all-important tapered drill end. Screws went in very snug, me being now-careful and paranoid about trying for a last turn!
Anyhow, in a world of over-hyped devices, these are the Real McCoy, IMHO. :)
I see that on the net, there are many other brands for similar tools, but the URL above is for the one I bought.
Edit: added pix: one with a whole #6 screw and the parts of another broken one afterI removed the threaded part.
So far, three screws backed out with no dulling noticed. Even tho it's made from hardened steel, it's bound to have a finite wear life, tho.
Even if you only get eight out of a tool, that's a buck a screw. That's well worth it considering the damage I've done with drills and vise-grips.
