I am about to get my boat hauled, sooner than expected. As a result, I am behind in figuring an issue out:
--> I have B&G 'Network Data' related set of instruments -- NMEA 0183 -- including windspeed and direction (masthead), depth, and knotmeter. These connect to a single choosable (any one measurement) readout at the chart table, and a set of three readouts in a pod on the steering pedestal.
The knotmeter always gets fouled, and I hear there are some now that you can just pull from inside the cabin before a sail and clean without fear of sinking the boat (some sort of sealing port?). I would like that.
The depthsounder cuts out occasionally, not a huge deal in the Bay, but not OK offshore around here. I suspect it's a ground issue somewhere.
As a result, I've been planning to replace both, and the time to do that is when the boat is hauled (and before the bottom-paint job). However, I really don't have the time/$ to do a full rewiring/electronics job right now... I am hoping there is an in-between option, and that is what I'd like advice on.
--> Does anyone here know if I can install new NMEA 2000 (or should I now only go with NMEA OneNet?) knotmeter and depthsounder instruments, and connect them to my Vesper 8000 AIS (which does have 0183 connections, along with 2000), and run that Vesper 0183 back out to the original B&G readouts (especially on the pedestal pod)? The Vesper is not yet installed, but that I can do on my own.
If that mixing of protocols / instruments is tractable, then (maybe?) I can keep my wind instrument (I am not unstepping the mast, so cannot change that right now) and also get the readouts from the new underwater sensors (knotmeter, depth) on the old pod B&G readouts.
--> Basically, I'd run NMEA 0183 Wind, NMEA 2000 speed and depth into the Vesper, then the 0183 out from the Vesper to all the instrument readouts, essentially using the Vesper to convert protocol from NMEA 2000 for the depth/speed to NMEA 0183 to the instument readouts in the pedestal pod.
Or is this all fantasy, and if I change the sensors now I need to change everythign at once? I like the wind instrument -- it's handy for me, so would be faced with keeping the current instuments or going to NMEA 2000 for the new depth/speed and giving up the wind for now.
--> Last question: assuming I change the depthsounder and knotmeter, what brands/models do you all recommend (boat is an E34-2 hull)? I certainly want a knotmeter that is easy to unfoul from inside the boat; otherwise there is not a big reason to act now.
Many thanks for any advice/suggestions!
PS: I am sure with time I could figure out some of this from the manuals, but I need to order parts ASAP to meet the boat hauling schedule, so am hoping one of you already knows (and would ask anyway to make sure I wasn't missing something big.)
