So I’m just venting my frustration about a new leak in the boat. I usually have a bone dry bilge with only a small amount of water getting in to the space around the rudder post from the rear dorade vents, and that only during windy rainstorms. Yesterday I found the normally dry bilge full of water up to the pump switch level. I discovered a leak through the wiring bundle from the mast step that is threatening to rot the compression post and damaged the floor. I guess two coats of epoxy didn’t prevent water getting into the plywood sole. The weep hole on the mast wasn’t clogged and there is a standpipe in the step that has worked for the last 4+ years so I’m mystified as to why it’s suddenly leaking. And now I’m mad that I’ll have to drop the mast to fix this problem.
Ok, now I feel better! Thanks for reading.
