windjunkee
Ok, so this one is very very odd and any input would be appreciated.
1970 E32-2 with an Atomic 4 engine. Raw water intake is on the starboard underside, maybe 1 ft to the outside from where the keel starts to slope down. The intake is covered by a brass strainer. When the boat was hauled in July, we took the strainer off, cleaned out the thru-hull completely and reseated the strainer.
Now the weird problem. When the boat is motoring flat or is on starboard tack, engine temperature remains constant at about 180 degrees with RPM's anywhere from 1500 to 1850. When the boat is on port tack and heel angle is plus-2 degrees, the engine temperature shoots up to 220 degrees. 5 degrees heel or more and the engine temperature closes in on 250, alarms sound and we have to back it off to idle, let it idle for a minute or more and luff the main to eliminate the heel angle, which will bring the temperature back to 180.
If we change tacks back to starboard, the temperature immediately drops.
Since the intake is on the starboard side, assumably port tack would cause the intake to be deeper in the water. The bottom is smooth so there is no turbulence being directed at the intake strainer -- at least none that we can fathom. All the intake lines are clear (i.e. no full or partial blockage). Exhaust water flow does not appear to be diminished in any way between tacks or flat water motoring.
Any thoughts?
Jim McCone
Voice of Reason E32-2 hull #134
Any thoughts?
Jim McCone
