Hello all! I am a soon to be owner of an Ericson 32 MKIII and just last Monday had the survey and sea trial. All I have to say is wow! I now own a Hunter 285, which is up for sale, but needless to say here I'm sure there is a world of difference between the two boats.
During the survey one of the items that came up was a high moisture level below the cockpit sole. The surveyor sounded the deck with his rubber hammer and it actually did well but the moisture meter pinned in the same area. No other problems any place else. He suggested that the best fix would be to drill holes up through the bottom of the deck (below the cockpit) every 6" but not through the top (of course) to dry out the core. Heat lamps would also help the process. After the core dried out then inject epoxy, again from the bottom.
I've never had this sort of problem before on my other boat and I'm sure there are other ways of taking care of this problem. The surveyor said that this was not a reason to walk away from the sale but that it needed to be taken care of within a reasonable amount of time. He also preferred drilling holes from the bottom to rertain the non-skid top surface which is very expensive to replace.
Being a new member of this site, which I found while looking for info on the 32, I'm sure I'll be coming back and asking more questions. Thanks!
