Head pressure is dependent on temperature....
AND
It sounds like you have a leak.
Most likely place is the evaporator. Most of these are aluminum roll bond evaporators, and are very easy for the user to damage, making them leak. They also are subject to corrosion, and what just looks like a little bit of paint missing, can be a hole that is letting the refrigeration out.
And
50psi for compressor head pressure is not likely to effect any cooling.
Guy
