Choices
This is an old thread you tagged onto started in 2006! I was surprised to find a reply by me on it. Well, I still haven't installed a windlass on my E32-3 but since then I did buy a used Maxwell VW 800 (Vertical windlass) that came with the capstan. I was planning to install it right behind the anchor locker and simply kick the chain and rode into the locker as it was winch aboard. But I also came upon another installation on this web site and have kept the photo which is attached. I think it might be a E-34 or E35 but it does show a customer frame that runs the perimeter of the locker and is attached to the deck. This set up seems like a sturdy design to me because the load is distributed over the entire frame. I can't use my Maxwell with this design so I'd need to get a different windlass. Also a hole would need to be cut into the anchor hatch to allow for the top of the windlass too protrude. Just another idea that I've been thinking about.
Your thread got hijacked by the inevitable discussion about pros and cons of various anchoring strategies.
Did you install a windlass?
It's on my near-term (this year) to-do list, so I'm gathering ideas about my options on a 32-3.
I'm not certain, but I think it may be best to be mounted just aft of the anchor locker, and engineered to somehow drop the chain down a hawsepipe through the forward end of the V-berth into the forward bilge - ideally aft of the chain locker, so that space can remain intact. But, then the chain would prevent the locker from being opened, unless there's some sort of chain-lock just forward of the locker's door, so one can slacken the aft part of the chain and lead it to the side if you need access to the locker while at anchor.
Any advice you can give will be much appreciated - especially any photos of a 32-3 windlass install
