Window Curtain Track Wall Mounting Bracket
stangc
Where might I be able to find replacement brackets to hold the window curtain track for my 1985 E30, per the photos? Stan Chamberlain, sgchamberlain@cox.net
Sailrite.com has lots of items for fabrics including curtain track and hardware. I don't think the metal clips are available anymore, but the plastic clips should work with your track.
I found the metal clips a year ago at a normal fabric shop as we were buying new curtain material. You might want to check those.
I just removed a bunch of them and will not be replacing them. I can send you as many as you need. PM sent.
