hello all
I was attempting to remove my shaft coupling today and long story short i now have 3 rounded over bolt heads. These suckers are seized on there tight and there is a signficant amount of rust involved. I ended off the night grinding off one of the bolt heads as i figure this is my only recourse at this point. The plan is to grind off the bolt heads ...drill out the keyway try and separate the shaft coupling and output flange in this manner. The boat has an atomic four not that this really matters as all couplings are more or less the same.....just for reference sake no this is not a split coupling. If anyone has any thoughts suggestions that might help out I AM all ears. I have a replacement coupling on hand so not worried about sacrificing the old ball of rust.
thanks jarod
thanks jarod
