Looking at a 1988 32-2 is this haul cord? I know the top deck is but no info on the haul?
Also is the model noted for cracking at he port and starboard side under the forward cleats ( cracks are dead center of cleats ) that are mounted on each side of bow anchor locker? Crack goes from outer rub rail to inside the locker.. Is this common????
Also is it a normal problem to have high moisture readings around helm pedestal?
