Bill,
I am now starting installation, stringers are in place. Before I drop in the engine, four questions.
1. did you use the existing thru hull
2. where did you place fuel filter
3. where did you place raw water filter
4. how did you route, and what did you use for the exhaust.
thank you very much
Kevin,
Things must really be moving along. Hope this is not too late. I have been away "sailing."
More on that story later! (I lost my mast)
In short:
I used the old through hull. I think it is barely sufficient. I have heard reports of Yanmar replacements not getting enough water during hard long trips, and it overheating. I will replace mine next haul out. I have had no problems even running at 3,000 rpm' s for 6 hours. I just did this last week.
I put the fuel filter port side, just forward of the tank on the vertical quarter birth wooden side. I placed it as low to the hull as posable for best flow with a low tank, but still have access to it for changing filters ect...
I have the small newer model racor spin on type. The filter fits between the upper housing and the lower plastic viewing cup. I think it may be model 400?
I should have a raw water filter. I do not. Let me know what you decide! I may be doing the same soon.
The exhaust really needs to be thought out well. If not, water can siphon back into the motor's cylinders and or ocean waves hitting the transom force water back up though the system.
First, only use quality hose and joints. Do not use PVC water hose joints like many people do. Under good conditions they work, but soon as your motor runs hot or some other thing happens you will end up blowing all the water into the bilge and worse. I am trying to remember the name of the proper joint. It is made of fiberglass I think. They look like it. They are available at most marine stores. Also use approved fuel line.
I used a Vetus "muffler." I think it is the smallest one they make, but am not sure.
The system flows like this. The main wet exhaust hose comes out the motor, under the cabin sole to the Vetus which is located just aft of the cabin sole, near the strut bolts. This seems to be the only good place for it that is lower than the exhaust manifold and amid ships. The hose is then run upward out of the Vetus toward the underside of the cockpit seating, Stb. side. The hose actually runs in the channel between the seating lid and the vertical portion of the cockpit. The hose then runs aft to the transom through hull, staying as high as possible to keep water from accidentally entering from the transom.
Now for the tricky part that I did not understand at first and apparently still do not. There are two 1/2 inch(???size) ports for circulating water out of the engine manifold or heat exchanger, (not sure sitting here at home) to a "anti siphon" system and then back to the manifold. One hose runs down under the sole, aft to the back side of the galley bulkhead. It runs upward as high as possible above the little door behind the stairs. At this peak there is a three way "T." The 1/2 " hose then runs back to the other of the two 1/2 " ports. The third port coming out of the tee is reduced for a small 1/4 " (size??) hose that runs down to the back end of the Vetus. I needed to tap a nipple into the Vetus to accommodate this hose. The purpose of this is to stop water from siphoning in back from the exhaust water into the manifold and into the cylinders. That being said I now am confused as to what it is truly doing. Here is my thinking and I MAY get it right and I could be WRONG!
If nothing is broken ( ie blown head gasket ) fresh water in the heat exchanger system has no way of leaking into a cylinder. Thus there is no need for an anti siphon sytem for fresh water.
On the exhaust side, raw cooling water from the heat echanger is mixed at some point with the engine exhaust to be blown overboard. I think this point is in the "riser" at the back end of the manifold. This junction point is where salt water can flow back through the path where exhaust from the cylinders comes from. So, somehow these two 1/2" hoses connect with the salt water chamber in the heat exchanger to stop the siphoning of raw water into the cylinders. I know this is not clear, perhaps you can figure it out and let me know.
Anyway, I hope this helps.
Please feel free to e-mail me back for more questions. I will be home more now. I will try to post a story of my dismasting soon. Suffice it to say check your chain plates for cracks. My forestay chainplate broke, metal fatigue. It cracked on the inside bend as the plate bends allong the bow and back to aim at the top of the mast. I think these forward chain plates are minimaly built and should be replaced on all Ericsons.
Bill
