Had an interesting and significant issue while getting a new prop installed. The cutlass bearing had completely seized to our prop shaft. Won't drown you with all the laborious details of how it was finally removed, but it's been replaced, and the strut and shaft were inspected and said to be structurally in tact. Hopefully the transmission is as well.
Have no idea when the seizure occurred, though it may have been a reason for the weird vibrations we felt at times during low forward RPMs last season. In August of '23, a leaking shaft seal was replaced, and the cutlass wasn't seized then, so this clearly developed sometime since. Any theories as to how that happens, and what is the general lifespan for a cutlass bearing? We do keep her in brackish water year-round, if that plays a role. (The previous owner pulled her every winter.) Will obviously be something I keep a closer eye on moving forward.
