AC Panel protection
Nowadays my insurer requires that the backside of the AC part of the power distribution panel be covered to prevent incidental contact when the panel is dropped open for inspection/servicing. I always was a bit nervous about this anyway, and the last survey included a requirement to make this (long overdue) upgrade!
:rolleyes:
I made up a cardboard pattern in the proper shape, and then flattened it and produced a drawing with mounting holes marked and bend lines dotted in. TAP Plastics inexpensively cut and bent it, and drilled it, and flame-smoothed the edges. Easy and quick for them to do in acrylic.
I drilled some shallow holes and mounted it from the backside so that no screws come all the way through to the front. Now I do not have to unplug shorepower while the panel is open -- although caution is still the watchword. :oops:
Loren in PDX
