The spinnaker on our 1984 E30+ came without spinnaker sheets. The specs sheet that came with the boat list the sheets as 55' in length and 3/8" dacron double braid line. Can anyone confirm that this is the correct length before I buy them--it would not be good if they were a foot or two too short.
Also, I would use the spinnaker mainly in quite light air up to about 8 knots, when my 125% headsail isn't quite enough to move the boat well. So I am thinking maybe to go to a smaller diameter sheet like 5/16" which would be lighter and not drag down the spinnaker clew and also cheaper to buy, but likely still plenty strong enough for my purposes. I know a smaller diameter line will also be a bit harder on the hands, but in using it mainly in light air, I'm not anticipating that much strain on the sheets in any case.
Some of my thinking is based on my use of a spinnaker on my previous boat, a 23' san juan, which had 1/4" spinnaker sheets even though it was a masthead rig and quite a large spinnaker. While I know that the E30+ spinnaker is larger, it is also a fractional rig which limits the size a bit.
Can anyone comment based on their knowledge/experience?
