Our original analog panel volt meter appears to have died yesterday...
Oh Well, it's been flakey for some time now.
I note that the replacements all seem designed fit the same round panel cutout. Good news.
Also, the way Ericson spec'd out the panel, the meter is only powered when the spring loaded toggle switch is pressed to read bank one or bank two. Perhaps this would eliminate changing to a digi model... I donno...
Interesting thing is that the analog types, while not nearly as precisely informative, even in the expanded scale versions, do not need "display" power.
OTOH, the digital one I looked at at the Blue Seas site specifies that "minimum power consumption" is .6 watt.
http://bluesea.com/category/6/23/products/8235
I realize that the lighted display needs power, but as nice as it would be to read the output in two decimals, I got to wondering how this potential power drain accrues. Their info does say it has its "Manual sleep mode blanks display for power conservation."
So, is the drain when it's in sleep mode... miniscule? Zero?
(back in Luddite mode again)
:nerd:
:nerd:
