OK, now I have myself worried. I came here to see if I could find out information on finding an O-ring replacement for the water pump cover plate and have been seeing threads about the impeller shaft removal. As it turns out the shaft came out on me when I replaced the impeller. I had no idea there was a snap ring on the shaft nor do I remember there being one on the Ericson 32 A4 engine that I first sailed on. Shows you what you forget after 15 or so odd years. So what is the general consensus on this? Do I now have to pull the pump and replace the shaft bearings?
