copied from prior message from Mark: "It is installed on the bulkhead at the aft end of the quarterberth, probably two feet starboard of the boat center line. The only electronics in the area is the main control unit for the autopilot which is maybe two feet away. (This is the maybe 6" x 8" box that all the wiring goes into, not the small control panel in the cockpit.) The batteries and systems breaker panel are at least five feet away."
If I read this correctly, the compass module was installed just about opposite of what the manual said to do.
OTOH, there was an older version of this unit with a control head that mounted on a clip in the cockpit and may not have used a separate compass module. Mine is an A4000S model, bought in late '94.
:nerd:
Putting it back in the stern means that even at a slower speed it is laterally displaced a lot during a turn compared to the center portion of the boat.
To assess the difficulty, one must consider that measuring the
very small amount of magnetism of the earth is difficult for any sensor. The location of the sensor needs to be as near to the pitch and roll center of the boat as possible. In most boats there are practical reasons for not bolting it to the bottom of the cabin dining table (!) but you do want it near that area. This is where the boat moves the least and so gives the sensor a fighting change to read those invisible magnetic lines that textbooks are always talking about.
The next chore is to separate that sensor from local magnetic interference, and that can be from simple iron presence (tools, cans of food, utensils,
any ferrous metal) and active local magnetic influences like pumps or fan motors. I try to keep it at least two feet away from these attractions and prefer three.
Sidebar: I pondered quite a while over where to mount our Autohelm sensor and how to run the wiring. Several possible locations were rejected due to wiring difficulties alone, and others due to obvious motors nearby. No problem since the install in '95, so the effort seems to have paid off.
Good luck on resolving this. The AP is an absolute necessity on most of our boats.
Best of luck,
ps: here is a current Raymarine link for the 4000 series, and if that's what you have, all of our compass sensor advice is worthless.
http://www.raymarine.com/SubmittedFiles/Handbooks/Legacy_Handbooks/Autopilot/AH4000.pdf
