Art,
In the attached Interlux guide they differentiate between using Interprotect 2000 for preventive purposes or for blister repair/osmosis. The former only requires a coat or two, the latter requires 4 - 5 coats with the paint tacky when applying the next coat, and then a specified time before applying bottom paint. Was yours a blister repair or mainly a preventive step after removing your previous bottom paint?
We had a full blister repair job done on our boat last fall, and I watched the yard staff pretty carefully throughout the weeks long repair. They applied five coats of Interprotect 2000 after removing bottom paint and gelcoat and grinding/filling blisters. They applied the next coat when the last one was tacky (the thumb print test) and then I applied three coats of Micron CSC bottom paint. We moved the jack stands to ensure all areas of the hull were done. When the boat was lifted from the stands for launching, I noticed that where the last stands were, a small amount of the bottom paint came off, despite having followed all the recommended dry times. I'm fairly sure that none of the Interprotect 2000 was affected, but it's hard to be sure. So depending on how much of your paint peeled, some of that may be almost inevitable. Others may have more expert opinions....
