Best Adhesive for teak plywood to FRP?
gregjp
Before a portlight re-bed I am currently removing the old rotted teak veneer plywood in the head of my 30+ and am looking for adhesive suggestions to attach the replacement teak plywood to the underlying fiberglass. All suggestions appreciated.
Mark F
Hi gregjp,
I've had good results with Loctite PL3x Premium polyurethane construction adhesive. Years ago when adding some paneling to the fiberglass/gelcoat on the interior of an E23 I glued a test piece of panel to the gelcoat. I waited a few days and tried to remove the adhesive and wood - I had to chisel it off!
gregjp
Thanks, Mark. Sounds promising. Probably like what's on there now. Doing a lot of chiseling to remove the old teak.
