Maybe a smaller pan...?
We'll be moving aboard our 35mkIII in a couple of months and have been thinking about options for a little larger sink at least one a decent sized pan would fit in, any ideas? has anyone swapped out for a larger any help or suggestions would be great
Thanks Cyn
From looking at a few other E-35-3's on YW, it looks like the stock sink is a single sink, pretty good sized, and it takes up most of the obvious room on that countertop to starboard as you descend into the cabin.
(Sidebar: this may be
the only advantage my double-sink Olson has over your lovely yacht!)
Seriously tho..... can you measure the cutout size and also the possible depth if a new sink could be fitted? Note that you still have to have room for the drain fittings...
Post up the inside measurements and depth of the sink you have now, too.
A double sink might fit into that spot, if the counter cutout could perhaps be enlarged a bit. Our boat has a deep sink and I would consider maximum depth a
good thing if living aboard. It's difficult enough to keep the soapy water contained, as it is now.
I was looking thru the Scandvik online catalog before I decided to economize and have our existing sink buffed out and polished.
http://www.scandvik.com/index.cfm/method/Shopping_Sinks/id/4.htm
Any large plumbing supply center might have good choices, too.
Perhaps a larger single sink could be fitted, as an alternative, but I sure prefer a double sink for washing and rinsing...
Best of luck, and do post up some "before" pictures, and then work-in-progress pictures.
