Rocinante33
My E-33 has been hauled for a bottom job. A P/O previously had a barrier coat put on, but they apparently used crappy epoxy that aborbs water....exactly what it is supposed to prevent! So, there were ~200 blisters to grind & fill. They quoted me ~10 hours labor @ $75/hr. I told them to do it, but they came back with 16.2 hours actual time spent. I am not happy about the difference.
They are also saying the keel to hull joint needs to be glassed in ~ estimate 4-6 hours more labor! (I know many Ericsons have encapsulated keels, but the Ron Holland designs are external lead keels). If I do that, the $1400 bottom job will run $3K! It has been fine like that for the 3 years I have owned the boat. Should I pass on that this time?
With sticker shock,
Keith:unsure:
With sticker shock,
Keith:unsure:
