I will be at the yard this weekend to hopefully complete removing the motor from the boat, pull the winches for a service, and just generally clean/organize my work space as I will be starting some of my other projects once the motor is gone.
One of my ancillary missions is to visit with the service department and organize having them sand/prep my bottom for new paint. I have already received a preliminary quote over the phone, so I am prepared for the cost.
Bare with me, admittedly I am not well versed on that which I am about to speak. That said, I am planning on relocating a couple of thru hulls above the water line (credit jkenan), which will obviously require some patching of holes. A process that as I understand would leave a similar condition as a blister repair, IE no gel coat. (I will complete this before I have them prep the bottom).
That means that I need to have them sand the boat down to the gel coat below the water line? Am I over thinking this because that is industry standard when you pay for a prep, or would they simply sand to smooth in anticipation of another layer of anti-fouling with out proper guidance?
Basically, I am looking for some advice on specific verbiage, request, ETC, that I should use when talking to the service department about my objectives so that when they complete the "prep", I would more or less just need to buy and apply the bottom paint systems (post repairing old thru-hulls, other items that might appear to need repair after sanding).
If I am way off base, please correct my path. I have read through this forum, numerous others, articles in all the major sailing rags. Just when I get the ah-ha moment I , read something completely contradictory, or at least more in depth that only confuses me further. Is there any reading you would classify as "definitive" on the topics of bottom jobs?
This seems to be the most concise info I have found, and what I am drawing my plans from in the absence of any direct anecdotal guidance you all might offer - http://www.boatus.com/boattech/articles/bottom-line.asp
As I my goal of sailing away this fall becomes more realistic, the possibility that I will not haul for a couple years weighs heavy so I really want to get these things right, which leads to the ever unproductive habit of overthinking .
Thanks in advance.
Thanks in advance.
