I had someone who knows what he's doing troubleshoot my not working bow running light. He concluded that the bulb, fixture itself and connection there are O.K., that the connection at the electrical panel is now clean and O.K, and that the problem may be somewhere in the wiring inside the bow pulpit, or from there back toward the panel. He says there may be a connection in the forepeak area that could be corroded, but the path of the wiring isn't clear and access in the forepeak area is difficult. Given that I'm probably going to now be doing some more digging myself, I thought I'd find out if anyone knows the "standard" route and wiring configuration that were used on the E32-200 from the panel to the bow pulpit. Also, is there a connection in the forepeak or pulpit area between two runs of wire? Thanks for any information you may have.
