Butyl tape revisited...
mherrcat
I removed and rebedded with butyl tape one of my portlights that was leaking. After trimming the butyl that squeezed out between the frame and cabin I was wondering if any other type of sealant needs to be applied around that edge.
jimk
Hi Mark, I dont have an answer to your question yet, however im about to do the same with one of my portlights what size of tape did you use.
Maine Sail
No you don't it will survive in UV for a very, very long time. You do want the frame to fit as tightly as possible though so when the sun hits it it does not continue to "ooze" out. As it oozes it is a good idea to re-tighten the screws to make sure the port is tight.
If you need any butyl tape, the good stuff 1/16" thick X 1/2" wide by 50', you can order it here:
Bed-It Butyl Tape (LINK)
mherrcat
Just the man I was hoping to hear from! Thanks for clarifying that and for the link.
I found some tape at a local RV repair and supply company. It is grey and about 3/4" to 7/8" wide and 1/8" thick. I don't remember the width exactly since it is now on the boat, but I do remember that it was about 1/4" to 3/8" wider than the flange on the window; I had to cut that much off before fitting it in place. Cutting off the excess was a challenge; you need a sharp razor blade or box cutter type knife and keep the blade clean or the tape will tear instead of cutting cleanly.
This stuff is very sticky so you have to be careful when putting the window in place. Once it touches the cabin surface that's pretty much where it's going to stay. It's not something that you can kind of "wiggle" into place. If it's not in the right place you'll have to pull it all off and start over with a new length of tape, otherwise the tape will stretch and you won't have the thickness you need. (I guess you could re-work the material and apply it around the flange again, but I was trying to get a continuous, flat, even thickness of tape all the way around the flange.)
My first attempt didn't work because I had to angle the front in first then push the back in. The butyl grabbed on the front and I couldn't slide the window back to even it up in the opening. I had to shave the opening a little to allow the window to drop straight in.
I wish the width of the tape were narrower but I like the 1/8" thickness. 1/16" seems like it might be a little thin for those frames. The inside of the flange is a little bit concave around the bends, so the tape needs more thickness to fill that area.
I've done some pretty serious water hose testing and so far there are no leaks.
treilley
Two tips for working with Butyl.
1. Keep a cup of fresh water nearby to dip your fingers in. This will keep it from sticking to you.
2. A small ball of butyl is useful for cleaning up small bits as it tends to stick better to itself then most surfaces.
Sid
BOATBUMMS
Captain Tolly's Creeping Crack Cure
Now you all might think that this is bunk but I have stopped many leaks this stuff ,it really works. I've been using it for years. In a work day on the boat I can multi-task here is a link;):egrin:
Makes for a finished job when you use it around the screw heads.
