Mildew in the locker.
All, David on E31, hull #44, Emerald, has holes in his hanging locker door so probably hasn't had problems with mildew there as I have had in the past. I solved the problem by installing two louvered stainless vent plates in the locker, one at the bottom of the door and the other at the top side. I mounted an old Kodak projector cooling fan behind the upper one, well away from the coat hanger bar, etc and have it hard wired to the AC system. So whenever I'm plugged in to shore power at the slip, that fan is running. I'll bet it's been there for 10 years and it's still going strong. I might add that prior to installing the fan, I pulled back all the ribbed fabric liner that is glued to the hull and washed that area as well as the rest of the inside of the locker with liquid Lysol from a bottle (not the spray which at one time was merely a deodorant and not a mold and mildew killer). I then glued it back with 3M Super 77 spray adhesive thinking foolishly that all would be well in there given that it came from South Carolina to live with me here in SoCal. Nothing could be farther from the truth, thus the fan which did the trick. Glyn Judson, E31 hull #55, Marina del Rey, CA
