This February marked my first full year ownership of a beautiful Ericson 30+, a true joy to own and sail. Over the summer I had been getting a trickle of water occasionally running down one of the stainless steel rods connected to the chain plate pad eyes. In attempting to remove the pad eyes from the deck in order to re-bed them I’ve run into a road block. From what I can see, the bottom of the stainless steel rods are screwed into anchors behind the seat backs and the top connected to square blocks of aluminum just under the deck. They are also notched for what I assume is to provide a flat surface for a wrench to unscrew them from their anchors. The pad eyes look to be connected through the aluminum blocks with 3/4’’ nuts. After removing the nuts and washers I could not get any upward movement of the pad eye bolts. I was able to unscrew one of the rods upwardly but that does not seem to make any difference.
Part of my problem may be that I’ve also discovered that the aluminum blocks have corrosion and pitting which may have seized the pad eyes to the aluminum blocks. Does anyone know what the proper steps are required to remove these pad eyes? I would hate to start hammering upwardly on the base of the bolts only to find out that I am missing a crucial step. Also, now that I have unscrewed one of the rods, is there a correct tension or torque on the rods once everything is done?
fficeffice" /><O></O>
