AGM / Alternator trivia
On the part of this thread about voltage output from a stock (Motorola) alternator....
I just replaced my "emergency/starting" battery yesterday. The former one died last week after four years. I have been using an AGM battery tucked under the aft berth in a custom box. This was done because the location precludes adding water if it were a flooded battery.
I next fired up the 23 hp Universal (easily, I might add (!)...) with the new battery and my digtal volt meter reads 14.13 to 14.15 charging volts at RPM's from idle to 2000 RPM, measured at the battery.
I note that the printed intormation that is enclosed with the new Optima (blue top) states that it should be charged with: "Alternator: 13.8 to 15.9 volts, Battery charger: 13.8 to 15.0 volts, 10 amps, Float Charge: 13.2 volts to 13.8 volts, 1 amp maximum current."
Then it states that a "Rapid Recharge" = "Maximum voltage 15.0 volts and no current limit as long as battery temperature remians below 125 degrees F."
I am still using the stock 50 amp (might be rated 55, but I forget) Motorola alternator.
Hope this additional info helps the discussion along.
Loren in PDX
Olson 34 #8
