Brian-
Great progress! Engine installation looks great. Tackling the galley is down the road for me (after the bottom, thru-hulls, etc) are done, but when I get to that point, I will certainly be referencing your work.
Question for you about your raw water intake manifold: how do you manage the risk of raw water demand being interrupted by a breach in the vacuum? Confusing question? OK. Let me explain: As a benchmark, raw engine water is normally supplied through a dedicated line that does not service any other unit. Once a manifold is introduced, and other units are 'on-line', what prevents the engine water demand from pulling water from the other units because it is 'easier' than pulling from the thru-hull, and eventually pulling air from those units?
In my ideal config, I would have head raw water intake and engine raw water intake being served from the same thru-hull. Will the seals in the head suffice to hold the vacuum? What if someone leaves the handle up (I've got the Raritan PHII head - and I ought to know it better if I'm going this route).
On another point, I was interested in your grounding plans for SSB. Do you have any plans to provide a ground for lightning?
Looking forward to your response (We're in the 'zone' for baby delivery, so I am definitely an armchair sailor/boat renovator for the near-term. Any reading I can get is greatly appreciated!)
