Mort Fligelman
Hello all of you E35-3 and big brother E38'?.....
I remembered searching a thread "Aft cockpit drainage/backing up" started by Gareth Harris......
I finally decided to check and see if my drains were crossed as per the instruction manuel......and they are.....SO......I find that Cory Bolton has the same problem that I do.....water coming over your shoes....but even more distressing that when heeled over on the starboard side, the water gets up to the engine instrument panel.....a bit scary....and could be a major problem, in addition to becoming expensive......
In checking the West Marine catalog, 2008, page 527 I have found a couple of scuppers that are Floating ball valves that should keep the water from backing up....
Has anyone used any of these??????
Any info or thoughts would be appreciated.....
Also....take a look at www.thmarine.com......
The Perko on the page looks good....but at $177.00 it ought to....
Thanks in advance for any thoughts!
