I am moving my facet pump and primary filter from the port to starboard side of my engine bay. When I removed the facet pump I discovered that the fuel line between the pump and the tank was metal tubing. There is a fitting on the end of the metal tubing to attach it to the pump port.
I need to extend the fuel line across the engine compartment to the new location where the facet pump will be located. I am wondering if anyone here has done that and how they did it. I would expect that there is a fitting that you could attach to one end of a fuel hose that would screw into the fitting on the end of the metal tubing.
Does anyone have any information about how to accomplish the attachment of a hose to a metal fuel line?
