Rick R.
There were 3 keel versions:
Deep fin 6' 1/2"See attached brochure.
Shoal draft 4' 4"
Wing keel 4' 5"
Thanks Brian!
Shoal draft 4' 4"
Wing keel 4' 5"
_________________________My wife and I went out on the boat yesterday with the owners.
We motored out of the marina to the open bay and raised the main. It obviously had not been raised in a quite a while as there was mud daubers nest that fell to the deck as the sail opened.
Raising (and lowering) the sail was difficult as the (Teflon?) sliders seemed like they or the track needs to be lubricated. The main looked pretty good, there was some green algae visible and the eyelets at the tack and clew were slightly corroded.
The headsail was a 150% Genny and the roller furling worked just fine.
Unfortunately the wind completely died down once we got out in the bay so we really didn't get to see her under sail really.
The owner and I went below to talk while my wife and his brother stayed at the helm. While we were below we hit some wake from a passing boat and I noticed that the mast moved back and forth slightly (is this normal)?
The steering was very responsive.
The diesel engine ran fine but they had a hard time restarting her because he said the bilge pump float got stuck and it ran the batteries down. He opened the engine compartment and released the compression release manually while his brother turned the key and she fired right up.
The standing rigging all looked fine, no corrosion or fraying, although the shrouds seemed a little loose and need tightened.
There are some minor cracks in the gell coat.
The onwer said they just did a bottom job three months ago. He said there were some very small blisters on the startboard side but he has never worried about them.
The rubber boot at the base of the mast needs replacing and the owner says he will fix that.
What were the CF links supposed to be to ?
-Sven
Clicked on, they are just labels for clickable url's for masses of thread links over on another boating forum.
LB
