Well, today I was able to replace the packing in the E38 rudder. Initially I tried 3/8" but that was too large and the manual called for 1/4" and that was definitely too small. This is beginning to sound like a children's story..... Ended up using 5/16" teflon/flax packing. The E38 has a flange with 4 bolts that compress the packing. There appears to be no adjustment like a propshaft setup. The only way I can see to correctly install is to tighten up the 4 bolts all the way. Anything less I think would work loose and/or not seal correctly. Any input on this would be great. This is not something I want to do incorrectly. Fixing it in the water would be a royal PITA. The rudder now has slightly less tension on it than before, what I mean is the effort to turn the rudder by hand with no steering gear attached from underneath the boat. I attribute the slight decrease in effort to all the grease I used during reassembly. Thanks, RT
