About a year ago, I said that I was going to refinish my newly restored deck by applying a non skid application. I ordered about 2 kits(gallons) of Grizzly Grip (textured paint), on line at www.grizzlygrip.com. After following their instructions, exactly!, and speaking with their advisors, I decided to try it.
their warranty says...>>."Only if there is a manufacturer problem, we do not warranty against peeling because that is a preperation problem. If your prep work is good, it will not peel or fail."<<
I applied their product onto my epoxy primer coated deck and prepared the surfaces as directed; scuffing with pad, washing down, wiping down with acetone, taping borders where I did not want the texture. Applied the Grizzly Grip to the deck areas I planned, first one coat then a second, after that it appeared to be perfect. about two months later I covered the boat for winter. However ,when I returned in March, I noticed a bubble in one of the areas, the another, and another, and then peeling and peeling. It is now almost one year old, and it looks like hell only worse... garbage.Now I have to strip off the garbage, and try something else.I have the pics to prove it, which I will post.Grizzly Grip is labor intensive and costly, the worst thing you could ever want on your boat.
Has anyone tried and believe in a non skid application, not thread master
