charlierusty123
Leigh Campbell
Well, the season has come to an end. This is my first year with the Ericson 29 and the Atomic 4 engine. Following the instructions for winter prep I started to drain the engine. I was able to get at 2 of the drain plugs but the 3rd one appears to be under the generator and without removing a lot of engine accessories. One example I saw was an estension which brought the drain out where one can get at it. Anyone know where one can get such a fitting or is it just made up?
Anyway after draining the two plugs I could get at I inserted the water intake tube into a 4 litre (yes, I am Canadian) pail of anti-freeze with rust inhibiters and drew that through the engine (you need to block the thermostat line to ensure the anti-freeze goes into the engine block). Once it starts coming out the exhaust shut the engine off.
