ky ed
Extreme Adventurer. E27 trailer sailor from Iowa
Well here is my big project now. Being able to raise and lower mast single handed. First did a good bit of research, and with prior experience i got a pretty good idea of how to do it. I saved up and ordered a large Dwyer mast hinge cost about 160 delivered, then ordered 5/16 cable clamps, cable saddles, and bimetal hacksaw blades. Firstly i had to get the cast aluminum mast shoe glued with 5200. It came free fairly easy once i heated it up enough to stink, then i drove a cheap thin 5 way putty knife between deck organizer and shoe after removing a pair of #10 phillips head screws. Screw heads about stripped the. but with my trusty mini vise grips they came out. Pulled out a 3" long piece of tube that was a conduit for wires. Was going to fill holes with epoxy but figured I didn't need to cause the Dwyer bottom hinge plate would cover all holes. Dwyer did a fine job with pre drilled holes, perfectly lined up with 4 holes in mast organizer plate. Thankfull for that cause stainless is tough to drill. I cleaned deck and bottom of hinge with brake cleaner to remove any oil. Then i put a strip of butyl around edge of hinge bottom and a piece over holes in deck organizer for good measure. Drilled 4 holes 1.25 deep through 4 holes to accept 4- 1.25" 5/16 stainless lag screws. I quicly noticed when i drilled holes into my 50 year old boat cabin top nice dry plywood shavings came out. Joy for quality boat build. Was expecting mouldy wet core but it was dry as pop corn fart, counter sunk new holes to allow more butyl around holes and lag screws to prevent leaks by having more butyl you get more stretch equalling less leaks. Plan on sailing this ole tub to the very end so want at least 15 years before we both go to the other side. To be continued.
