I kicked this around with another member in a private chat, but I wanted to open it up for suggestions.
I have nailed down a final design of the chain plates for the shrouds, dry fitting and locating exact bolt holes tomorrow.
The Fore stay plate, is pretty strait forward.
The back stay though, leaves some options. The first question for E-29 owners is, do you have a split or single stay? I have a single, but the member I have been chatting with has split. It came that way and they left it that way when replacing the chainplates. I don't know which is OEM, or if both were options.
I am not against splitting it, but I would absolutely get a rigger involved if I was going to go that route. It does seem like the better option for moving to external plates (splits the load to 2 chainplates, locations on the transom, ETC).
BUT... the single design has worked fine for 40+ years. Does anyone know what the chain plate that is bedded in the transom looks like? Is it just a strap the same width as what is exposed all the way through? If so, in theory I could drill through bolts through that strap much like I am doing on for the shrouds.
If anyone has cut their transom open or replaced the aft chainplate(s), any insight would be appreciated.
Conrad
Conrad
