Local fun
Well, I hope they didn't trash me too badly-that group and I have lot of history together. I'm glad the Choate thing worked out. Trust him-you will be happy with the result.
I'll make point of speaking to Sammy-while I definitely have my opinions about the A-sails, I would defer to him since he is working with you.
My feeling is that sure, a .5 is very important to have in your quiver for a long race-A-sail or otherwise.
For me, I think a full sized .5 AP A-sail and another AP or runner A-sail of 100% Airex 650, or maybe 600 in the back and 700 in front-they weigh . 6 and .7 respectively) would cover 90% of kite carrying conditions and get you into more wind than you want to carry a kite in.
I assume you have an old heavy air kite for a backup-just in case.
In light air, these will reach very close to the wind, and he is 100% right that your boat will do better genoa reaching if it is breezy-and this is why a reaching kite is probably not of much value.
The reason I would go with A-sails instead of symetricals is that they will certainly reach closer-with or without a pole than a sym kite, and when heavy running, they will not oscillate nearly as much as the sym kite-making the boat significantly easier to steer than it would be with the sym kite-and this WILL be an issue if you get into some heavy running (although the new rudder will help a lot). It is no fun doing the death roll dance, and these sails help reduce this. In normal conditions a full sized A-sail of the right design can sail just as deep and just as fast as any symetrical or faster-just use the pole as you normally would-squaring back more the deeper you go.
I will get a message to Sam over the weekend-he knows our mutual friend Bob Lane-and Bob has my #.
He might be thinking I was suggested reaching-type A-sails as opposed to the AP/Runner/Full sized.
Regarding instruments, the top of the line would be B&G or Ockam. They are not cheap though, and while the Raytheon race stuff is certainly not up to the standards of either of those, for many it is worth looking at. The Beneteaus I have sailed the last 3 Macs on all had the upgraded Raytheon stuff and it was certainly adequate-once it was calibrated-and it had all the functions you would need: TWD, TWS, TWS, Target speeds from Polars, etc.
Add that and connect to a good GPS/Plotter and you can optimize VMG to a waypoint-taking your sailing angles into consideration-very handy stuff.
My .2 Cents.
I'll be in touch,
S
My .2 Cents.
I'll be in touch,
S
