Chris:
Re single handing the E-33. Actually, it's not too difficult, if your boat is properly equiped. The really tricky part is keeping the boat head to wind while you wrestle up that big, heavy main. And again keeping head to wind when you drop the main. (Incidentally, Lazy Jacks or E-Z Jacks make life a whole lot easier, main wise.) I use our autopilot the hold the course while I get the main up, and down. Without an autopilot, I think setting the main would be a bit of a challenge, especially if your main uses a bolt rope and has to be hand fed into the mast slot. (There is a lot of main - it doesn't go up either quick, or easy.) A main with slugs makes things much easier, as long as you have some means of preventing the slugs from falling out of the mast slot. I also routinely use the autopilot to steer the boat while I trim the main and genny. As Loren says, it is possible to trim the main from behind the wheel. Lock the traveler into position on centerline and leave it there. To trim the jib sheets, I use the primary winches as turning blocks and bring the sheets back to the secondaries, which are within reach from behind the wheel. Bottom line: If you have a bolt rope main, no Lazy jacks, no Autopilot -- you are going to have more of a challenge than you can imagine, IMHO. Successful single handing requires a well, and properly equipped boat, and a skipper that knows what he/she is doing, again IMHO. I should also mention docking a 10,000 pound boat in adverse conditions (brisk cross wind, adverse current, etc.), single handed, w/o help on the dock, is a whole 'nother challenge. You no doubt already know all this, so I'm preaching to the choir -- sorry 'bout that.
Mike Oxborrow
E-33 Hull #25
J.P. Foolish
