I have an 87 E 35MkIII with a Gori folding 2 blade propeller. Max speed is about 6.2 kts at 2500 rpm on the M-25XP engine. Engine will go to about 2800 rpm but with no additional speed. However, at 2100 rpm speed down to 5 kts, and in any kind of seas or headwinds speed falls in 3.5-4.5 kt range at 2300-2400 rpm.
My questions are: 1) do these speeds strike others as slower than expected, and 2) how much of it is due to the Gori Propeller? Don't know propeller model or pitch (installed by PO), but when hauled boat for survey prior to purchase noticed blades covered with light pitting-wondered if this could explain performance of prop, of if I am just facing the tradeoff of low drag under sail for limited performance under power.
Thanks in advance for any thoughts.
Jeff Barrett
Jeff Barrett
