    2024-2025 Fund Raising Info
E27 prop questions
SV_Ariel
Thanks for everyone’s help. I did redo my reduction. Down to 2.6 to 1 and that greatly increased the acceleration without touching the prop. I am still going to change to a three blade this winter.
Elgyn- I am using two Power Queen 25.6V 100ah, LifePO4 batteries. I can’t remember what I paid for them but I think it was somewhere around $1000 for both. My boat is on a mooring so I barely use the motor. We typically sail off the mooring then use the motor a little bit coming in. I’ve never had the batteries below 90% yet so I can’t speak to any battery lifespan.
SV_Ariel
I did switch the drive over to belt drive as well. The chain was only temporary until I figured out what final drive I needed. It is incredibly quiet now.
Mark F
Hi Elgyn, I've got two banks of LiFepo4 batteries. One at 160ah and another at 40ah. I like having two banks - backup if one has issues. 400ah should get you motoring for days ;-)
Elgyn
Good to know. I have to motor about 1.5-2hrs to get out of the Fraser river before I can do any real sailing. Also keeping a range extender(aka an outboard)on the back as the winds tend to die out in between the Gulf islands and Desolation Sound
Solarken
Can’t seem to find any info in the search bar for E27 propellers.
I have what I assume is a stock prop on my 74 E27. I have recently swapped out to a Thunderstruck EV system. I think I need a larger prop. The electric motor spins the shaft like mad but it just doesn’t seem to have any giddy up.
The boat is incredibly sluggish at initial throttle. I never ran the boat with the previous A4 so I have no frame of reference on the props performance.
At first I thought my prop had fallen off because the motor was going like mad but I barely was getting movement.
Anyway, it’s a 2 blade prop, that’s about all I know. Never measured it. I’m thinking of getting a higher torque low pitch prop, probably three blade but I don’t know what size will fit. Anyone know the diameter of the stock two blade propeller?
For years I ran a Tohatsu 6hp with the high thrust prop and it moved it really well. I thought for certain using the prop right in front of the rudder would have given me better performance.
I’m all electric. My indigo was horrible even after I had it recurved.
First question. What is your gear ⚙️ ratio? Motor rpm to shaft rpm?
Next item. I had a custom prop made. Can’t use a 12” because that’s ⅝” from the keel. So I had an 11” made. 3 blades 13” pitch. WoooHooo! Bites the water great! I am 1.8-1 so 1800 rpm turns the prop shaft at 1000 rpm. I usually run at 1350 rpm for about 3.5-3.8 knots and low battery draw.
im a 1975 32-2 loaded to 11,600# with gear, water, food, so on and me. 10kW electric yacht “Quiet Torque” I can do 6 knots but don’t bother unless I’m bucking wind or current.
Solarken
On a long haul in no wind I use a Honda 2kW generator to keep my charging going at 22A and I drive the boat at about 3.5 knots using 20-24A so the batteries stay pretty full. I did a 27 km crossing with no wind into light current and swells and used 2.2 gallons of gas ⛽️ in the generator. Batteries were nearly full when I arrived.
Solarken
I'm looking at the same 5Kw (but water cooled) system for my e29. I like my 9.9 outboard, but it's a P.I.T.A. to raise/lower. I believe a 12d x 10p 3 blade is about the largest that can fit without snapping the 3/4" shaft at the most inconvenient time and will still do any sort of regen. Not sure if that info is relevant to your e27
Regen is a small thing. Maybe 170W is the best I’ve seen.
