bnye
I am in the process of purchasing a one-owner 1988 E-28 that appears to have been well maintained with a few notable exceptions.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o> </o>
1) The mast which at some point was painted white is losing its paint in large chunks from top to bottom. I would guess that 15-20% of the mast surface area is now exposed. I can see some minor bubbling of the paint around the edges of fittings and when you scrape the bubbles, some white powder is exposed. The fittings that I can examine do not appear cracked or loose (The boat is on the hard and the mast is still stepped). In other places the paint appears to have just peeled away. The <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comffice:smarttags" /><st1lace w:st="on">PO</st1lace> had the mast inspected two years ago and some maintenance work on the sheeves was performed. No other maintenance issues were noted at the time. Other than the paint, the surveyer did not find any issues with mast or rigging.
2) The water heater is in sad shape and will need immediate replacement.
My questions are:
<o> </o>
A) Should I have the mast unstepped and further inspected this winter (perhaps repainted) or should I simply sail the boat next year and have a better idea of maintenance/improvement issues and priorities for the following lay-up. BTW the yard quoted $3400 to repaint the mast with Awlgrip.
B) I am considering replacing the water heater myself. I am probably on the higher side of average for DIY skills, although far from a professional. Is there something about this task that would warrant paying yard prices to perform?
<o> </o>
Although I am a new member, I have been lurking on this site for the past few months while going through our boat purchase selection process. It has been very helpful to read the opinions and they certainly contributed to our decision to purchase an Ericson. I can tell you that this site is one of the best of the many owner sites that I have prowled around on in the past 6 months. Kudos to you all.
<o> </o>
Looking forward to becoming a part of the E-community.
<o> </o>
Bill
<o> </o>
<o> </o>
My questions are:
<o> </o>
<o> </o>
<o> </o>
<o> </o>
Bill
<o> </o>
<o> </o>
