Can you please elaborate on the E29 cockpit drainage system - how it works, how to maintain, which valve to open/close and when, what is standard and what's custom changes, experience ... In those E29 pdf manuals I downloaded there is not much about it.
A week ago I had a mechanic working on my A-4 and he accidentally noticed a leak in the cockpit drain hose on the port-side that is connected to the through hole right above the waterline (or it's below?). I was pumping out the bilge and he was installing fuel filter on the port side under the sit and noticed the leak. He told me that if the through-hole goes underwater (when somebody steps on the boat or heavy load in cockpit) the water starts leaking. He thinks that this explains why my E-29 was partially submerged. Earlier I posted that I bought my E-29 really cheap and sometime after I found out that the boat was partially submerged (that explains low price). The mechanic found a lot of water / rust in the starter and there was faded paint on the A-4 cover, head wall, some mud traces. E29 draws 4.5 and I have 6.3 in my slip and this is why the boat did not sink completely. He supposes that during the winter ice developed and under its weight the through-hole went under waterline and the boat got water because of leakage in the hose. Is he right?
But it is not all about sinking yet. While fixing the port-side hose (t-connection to be precise) he closed the port side valve that is in the battery compartment. He told me that the boat should be fine with the just starboard valve open. When I came on the boat in a few days on my lunch break for the cell phone my friend left on the boat I saw a lot of water in the bilge and the kitchen sink full of water. I pumped out the bilge with manual pump and the sink with bucket and only then I realized that water from cockpit goes to the sink because of the closed valve. I have two-section cockpit (captain and passengers) and it looks like the sections are independent.
As a total newbie I did not realize how important is this seemingly simple thing. It sank my boat the first time and almost sank the second time. I am going to do some serious homework about cockpit drainage. I plan to apply flour or chalk everywhere, close/open valves and pour water to cockpit and watch traces of leakage. I will launch dinghy and put the hose with running water to every single through-hull I can find.
Any input will be greatly appreciated.
