Ericson 30-II
Hi, I am about to replace the wire rope portion of my wheel steering. Has anyone done this? I assume my boat is very similar to the E30+.
I need to gain access to the area below the pedestal.
When I go inside the cockpit locker on the port side I cannot access the area directly below the pedestal. There is wood around this area that prevents any access.
On the other side in the aft berth there is some decorative carpentry around the base of the pedestal. This "carpentry" is mounted using wooden bungs that can be removed.
My question, do you suggest I disassemble the carpentry to gain access or go from the locker side and cut some wood away to get access?
Any pointers before I start wrenchin' would be appreciated.:nerd:
Regards, Bregan
Regards, Bregan
